RT6PK
I finally found the source of the leak on my 727. It is a little 1/2" plug that looks like a little freeze plug. It is located just above the rear of the pan. Now, can anyone tell me what this plug is? Does the entire trans have to come out and apart to fix/replace it? It looks like part of the tail shaft casting is partially blocking it. Can I just use some of that Blue Devil Trans Stop Leak? If I drop the pan, can I JB Weld it from the inside? Would silicon be better?
