YY1
Browsed through the Apr issue of Mopar Action at a local supermarket.
In an article of "tech tricks" it advises "...can't get enough negative camber?....add a shim between the LCA and the LBJ/spindle...1/4" (IIRC) is enough"
Doesn't that basically make the spindle the same height as the 73-79 spindle we were so vehemently warned against using?
Interestingly, 2 pages later in the same article they say "...if you read the 'disc o tech' article, then you know how to upgrade to disc the right way..."
