FOUND 73 B-Body K-Frame small block
73PlyRR
5:32 PM
Virginia
Feedback: 1 / 0 / 0
Looking for a K-Frame for a 73 B-Body with control arms and linkages.
I did some reading thats a pretty hard part to find. Looks like a cordoba kmember will work. Something about the 73 to 76 being different than say a 66/72 Kmember. So you have to either get a 73 or source a Cordoba Kmember. I have a complete 66 I was going to offer up but Pretty sure it wont work for your application.
I did find this one on Ebay.
https://www.ebay.com/i/254137185642...MI2bavu5X-5gIVFuDICh2SygY8EAQYAyABEgI5CvD_BwE
73 and up ,they have the rubber isolators not sure how far up . I Chuck them no one ever wants them . I'll see if my scrap guy still has any laying around he holds stuff till he has a full load
Wow that eBay ad! Doesn't mention if it's BB or SB K frame. 1973-76 B Body K frames differ between BB & SB.
I have a big block K which wont work for you as your looking for small block (needs to be worked anyway) but I have control arms Upper and lower (new lower ball joints and bushings) and have the drag link with good used idler and pitman, also have the swaybar and linkages plus more. Unfortunately shipping would be lot and you'll likely be able to find a better deal closer to where you are.
https://www.kijiji.ca/v-view-details.html?adId=1470255517&siteLocale=en_CA
Looking at it that one appears to be a small block unit... Also looks like the reason it was pulled out was it was way to rusty to use like most get around the Isolator bushings.....
the 73+ISO K's are notorious for the rust around the rear drivers. I swear the original splash guard directed water too it! lol It was a seriously bad design imo
73 to 79
Satellite, Charger, Coronet, Cordoba, Magnum
all the same
some base models do not have sway bar mounts (on the K frame) but most do
BB is slightly different than SB but Mopar used to sell a motor mount to put a BB in an SB K
Thanks for the replies, I am looking for one local to Virginia if possible. Shipping one will be a killer. Also will a 74 fit a 73?
Oh yeah shipping these days is not cheap
Yes the 74 will directly fit 73... 73-79 B's the K is the same other than the engine mounting between /6, SB & BB and having or not having the sway bar link mountings but most will have them.
Note on the 73 lower control arms. they may have the one year only screw in type ball joints. Good news is the later press in ones are interchangeable between the 73-79 K's
I have a 73, PM me if your still looking
I have one still in the car. Not far from you. I can remove it for you. I am in PA. Not far. let me know or PM me
