FOUND 73 Roadrunner: Brake Parts
Madmopars
3:03 PM
Tucson, AZ
Feedback: 2 / 0 / 0
Looking for a master cylinder mounting plate and proportioning valve for a 73 Roadrunner with manual disc brakes. PM with details. Thanks!
I don't think that was an available option from the factory on B body cars.
IIRC was an A body thing.
Is the plate you are looking for different than a PDB plate?
The firewall mounting plate as well as the attaching hardware to the pedal is different between the two and although I'm not an expert, I believe manual brakes were available on the 73 B bodies though I could be wrong. My 73 Roadrunner looks to have been originally manual brakes and I converted my 73 GTX to manual brakes years ago using parts from a 74 Coronet as I recall. I can't speak to the interchange on the proportioning valves yet though.
Edit: FWIW, it looks to interchange from 70-74 B and E body. Doctor Diff shows an aluminum version for $40 but I would still need the pedal hardware and proportioning valve. The search continues... :thumbsup:
Picture: Power brake mounting plate vs manual brake mounting plate (installed)
So you need the mounting plate (yellow arrow in pic) and not the other one (blue arrow in pic) correct?
I have the blue arrow plate, thanks.
I'm looking for one like the yellow arrow is pointing at.
I can’t help with parts but 100% that manual brakes were available on 1973 Road Runners. That’s how mine is and it’s stock.
