Thanks I’ll give it a tryI took a skin from a 74 Satellite and put it on a 71. As Mark said, it is interchangeable. I will also say it was the easiest piece of sheet metal I ever installed. It only fits in one spot!
I wouldn't steer you wrong. Hopefully you were able to get info on it and secure a deal. Safe travels.
Yep, the seller is restoring a 73 GTX asked me to double check. Definitely appreciate your help .I wouldn't steer you wrong. Hopefully you were able to get info on it and secure a deal. Safe travels.
I really like this thread it’s gonna help a lot, thank youIf you go here, StuBBle has left the field., you may find a trick or two to use. If you so decide.
