wagonman
- 6:36 PM
- Aug 1, 2015
- Deming New Mexico
Howdy All, I am setting up a 742 with all new everything from Dr Diff. I have pinion preload @ 15 in lbs. Installed the ring and carrier, set B/L to 10 and ran a pattern. looking at the pics can you advise what shim I should start with under the Pinion. I started with a 0.060 I have a new bearing I honed for ease of set up. Coast is barely on the toe and the drive is almost non existant
