77 Dodge 3/4T 440/727 3.54 SG Dana 60
racedodge
9:40 AM
Eskridge, Kansas
I THOUGHT I NEEDED IT, BUT MY 88 DODGE IS DOING JUST FINE FOR MY NEEDS. PLEASE PASS ON TO ANYONE YOU MAY THINK WOULD BE INTERESTED.
THE GOOD:
1977 2WD, 3/4T, 440 (FORGED CRANK MOTOR), 727 TRANSMISSION, 3.54 SUREGRIP DANA 60, CRUISE CONTROL, A/C, FRONT AXLE 3300#, PWR DISC BRAKES, 63 AMP ALTERNATOR, 20 GAL CAB MOUNTED GAS TANK, BLUE TRIM SET, DUAL ELECTRIC HORNS, UPPER MOULDINGS, SPRING FRT 1475, AUX SPRINGS REAR, 12X2" DRUM BRAKES, TRANSMISSION OIL COOLER, DELUXE WATER PUMP, 25 GALLON REAR GAS TANK, CLOTH/VINYL INTERIOR, TACHOMETER, HD FLASHER, LOWER MOULDING, 16.5X6 WHEELS, SPRING REAR 2500#, HVY DUTY SHOCKS
4 A/T TIRES ARE DAMN NEAR BRAND NEW, IT RUNS AND DRIVES, THE LIGHTS WORK, HAS A CLEAR MISSOURI TITLE.
THE BAD: 727 LEAKS FROM FRONT PUMP SEAL, REAR STEEL BRAKE LINE NEEDS REPLACED, DRIVER'S SIDE EXHAUST MANIFOLD NEEDS REPLACED (HAS REPLACEMENT JUST NOT MOUNTED OBVIOUSLY), SOME RUST IN FENDERS, ROCKERS, AND ROOF SEAM, BUT NOTHING THAT CAUSES LEAKS INTO THE CAB, DRIVER'S SIDE FLOORBOARD NEEDS A PATCH
STUFF THAT GOES WITH IT:
EXHAUST MANIFOLD
BRAKE LINES
BRAND NEW RUBBER FLOOR MAT WITH INSULATION/SOUND DEADENER
BRAND NEW AIR FILTER (MOUNTED)
BRAND NEW ECU AND COIL (MOUNTED)
PRICE: $1500 OBO, YES I KNOW IT NEEDS SOME WORK, BUT ITS A FORGED CRANK 440/4BBL, HAS A SUREGRIP 3.54 DANA AND IS A PRETTY LOADED TRUCK TO BOOT.
NO REASONABLE OFFER REFUSED. WILL POSSIBLY TRADE FOR 60/70/80 MOPAR CAR/TRUCK OR PARTS.
THANKS,
JAMEY
620-757-1284 CELL
785-449-2657 HOME
MORE INDEPTH PICTURES ARE FOUND BY CLICKING BELOW:
http://s475.photobucket.com/albums/rr116/solomonredrage/mopar/77 truck/
If you weren't in KS, I'd be all over it. I've always loved those trucks.
Good luck on the sale, I think its a pretty good deal!
