8 3/4 Help What is this?
Wedgeamacallit
10:19 AM
OHIO
Hello all. Pulled my 8 3/4 third member out and found this
laying in the housing. No idea what it is. Thanks
B3B14223-B842-4CB8-A60F-E23834194F84.jpeg 86F04070-B6A2-4A4D-8319-68EC16EF9EEE.jpeg
Thanks I will take a look at it tomorrow. I’m installing the green axle bearings and I believe you are supposed to remove that anyhow
Is there a difference between open diff and sure grip, I've seen 2 different varieties, but both were 2 halves held together with a roll pin.
The broken one came out of a open rear end or a cone Sure Grip but they are different between the two. The one in the picture above goes to a clutch type unit.....
I would check to see if that came out of the diff u pulled out. Cause if it did the housing may be damaged where the bearing fits in. Cause there would of been way too much axle play. Kim
