8.75 rear axle question
Engine, Trans & Driveline
  1. Dave P
    Dave P Active Member
    31
    12
    Apr 21, 2021
    Michigan
    Local Time:
    10:17 PM
  2. dadsbee
    dadsbee FBBO Gold Member FBBO Gold Member
    9,494
    22745
    Jan 29, 2018
    Midland Ontario, Canada
    Local Time:
    10:17 PM
    This should go 6 pages.. :lol:
    • Like Like x 4
    • Agree Agree x 2
    • Dave P
      31
      12
      Apr 21, 2021
      Michigan
      Local Time:
      10:17 PM
      As pointed out this is a driver...nothing special. I don't have any issues doing it either way. The setup I
      linked above just seems cleaner/easier and maybe less likely to leak in the future.
      Was asking to see if maybe was overlooking something.
      Didn't know ( new here ) that it was going to be a beat the dead horse type of thing....should
      I ask a "oil question " also....just kidding, I'm not that dumb.
      Dave
      • Like Like x 2
      • dadsbee
        9,494
        22745
        Jan 29, 2018
        Local Time:
        10:17 PM
        Put Timkens in it again and set it and forget it for the next 50 years...
        • Agree Agree x 7
        • Like Like x 1
        • R/T Boy 67
          R/T Boy 67 Well-Known Member
          927
          865
          Apr 23, 2018
          Nanaimo B.C. Canada
          Local Time:
          7:17 PM
          I am a timken guy, but If you do go with the green bearings, do not use the ones with the attached flanges. Get them from Dr Diff.
          • Agree Agree x 1
          • Ron H
            Ron H FBBO Gold Member FBBO Gold Member
            4,536
            4773
            Feb 29, 2016
            WI
            Local Time:
            9:17 PM
            LOL!
            • Agree Agree x 4
            • 33 IMP
              33 IMP Well-Known Member
              5,280
              7104
              Dec 21, 2017
              taxifornia,soon 2b Arizona.
              Local Time:
              7:17 PM
              Wasnt there a thread on this forum about someone whose "green" bearings self-destructed in about 20 miles?
              • Agree Agree x 3
              • Ron H
                4,536
                4773
                Feb 29, 2016
                WI
                Local Time:
                9:17 PM
                Aha - yeah there's a TON of posts on this the OP could scan. The views on tapered vs sealed bearings reminds me of the PF, lol.
                • Like Like x 1
                • R413
                  R413 Well-Known Member
                  1,756
                  3583
                  Feb 4, 2019
                  NW USA
                  Local Time:
                  7:17 PM
                  The stock tapered bearings ARE an upgrade. Chrysler did it for us! Don’t look for anything else. If you can’t figure out how to adjust them ask the question. It’s as easy as falling off a log.
                  • Agree Agree x 3
                  • Like Like x 1
                  • Longknife
                    Longknife Well-Known Member
                    184
                    197
                    Jul 12, 2017
                    Illinois
                    Local Time:
                    9:17 PM
                    If you are wanting opinions I will give you mine..,,,First are you sure its axle bearings??? After confirming its axle bearings, I would replace with the stock style quality taper bearings, set preload and live a happy life!!!! IMHO,,,,
                    • Like Like x 1
                    • Agree Agree x 1
                    • 66Satellite47
                      66Satellite47 FBBO Gold Member FBBO Gold Member
                      4,834
                      3849
                      Jan 15, 2015
                      St Paul MN
                      Local Time:
                      8:17 PM
                      If you have a daily driver use the Timken tapered bearings. You should consider if the pinion bearing is the issue.
                      • Agree Agree x 1
                      • F4R/T
                        F4R/T Well-Known Member
                        1,262
                        1623
                        Jun 17, 2020
                        Illinois
                        Local Time:
                        9:17 PM
                        Taper is a better bearing then a ball bearing for side loads and carry capacity if they both have the same number of rollers and measurements are the same through out... 50 years is tough to beat, get made in USA Timken not the koyo ones in Timken boxes... Koyo bought Timken .
                      • Fran Blacker
                        Fran Blacker FBBO Gold Member FBBO Gold Member
                        9,725
                        9321
                        Sep 23, 2016
                        Connecticut
                        Local Time:
                        10:17 PM
                      • Dave P
                        31
                        12
                        Apr 21, 2021
                        Michigan
                        Local Time:
                        10:17 PM
                        Ok....tapered it is. As mentioned I'd do it either way.
                        Pretty sure it's an axle bearing, previous owner had adjusted them ( without
                        pulling and cleaning/packing them ) to "zero" or less end play. I backed the adjuster
                        off to about .010 freeplay and noted the one side leaking. Noise substantially reduced
                        but still there with very slight cornering or side load, differing depending which side
                        of the car I load.
                        It's not the front wheels.
                        Sorry for digging up the previously beaten horse !
                        Dave
                      • RJRENTON
                        RJRENTON FBBO Gold Member FBBO Gold Member
                        1,698
                        1512
                        Jul 1, 2015
                        South Shores area of Decatur, Illinois
                        Local Time:
                        9:17 PM
                        At the very minumum six (6) pages.....my guess is 10 pages.....both ways....for and against...or my way is better than your way ..but, what if it was the carrier bearings and not the axle bearings.....
                        BOB RENTON
                      • Lefty71
                        Lefty71 FBBO Gold Member FBBO Gold Member
                        1,816
                        1962
                        Mar 8, 2018
                        Ohio
                        Local Time:
                        10:17 PM
                        Then fix the growling noise??
                      • RJRENTON
                        1,698
                        1512
                        Jul 1, 2015
                        Local Time:
                        9:17 PM
                        REALLY???!!!......an outstanding observation and recommendation....but fix what????....axle bearings or carrier bearings...
                        BOB RENTON
                      • Ron H
                        4,536
                        4773
                        Feb 29, 2016
                        WI
                        Local Time:
                        9:17 PM
                        The lack of end play adj if it had been driven much could have damaged the bearings. This alone would prompt me to remove them and inspect. Rear wheel bearings (which side) can be sometimes identified by driving the car around l&r curves or cornering - as for the rear end gears, a skanky ring/pinion can give off a wobbling sound, such as like spinning a dinner plate set on a table unevenly if you get the idea. Other thing trying to ID a possible bearing noise issue is to put the car in neutral while cruising to see if sound you're hearing disappears.
                        Ahh...green bearings? My 1st set went kaput after some 800 miles, I'm on the 2nd set and have maybe 1200 on those and so far so good. Scuttle butt was some earlier ones were bad. If these go, I'm going to go back to what mom mopar had. I can be gullible sometimes from bud's suggestions - was no friggin reason to change; but when putting in a different gear set made da change.
                      • Fran Blacker
                        9,725
                        9321
                        Sep 23, 2016
                        Connecticut
                        Local Time:
                        10:17 PM
                        Coming up on Page 2!
                      • Ron H
                        4,536
                        4773
                        Feb 29, 2016
                        WI
                        Local Time:
                        9:17 PM
                        LOL!
                      1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
                        By continuing to use this site, you are consenting to our use of cookies.
