ericisback
Is it possible for a 69 440 GTX to have 915 heads, from the factory? The fender tag shows a “915” engine code.
915 heads are 1967 only. There were two versions. Standard had 1.60 exhaust valves and HP had 1.74 exhaust valves. Read my previous post.
Presumably a Lynch Road car then (RS2xL9A) and "915" is top-left 2nd line. (Other plants don't code this to the tag in this manner) That is the code for the engine assembly, not its heads. TheThe fender tag shows a “915” engine code.
Mark Levi's post is entirely correct.
Presumably a Lynch Road car then (RS2xL9A) and "915" is top-left 2nd line. (Other plants don't code this to the tag in this manner) That is the code for the engine assembly, not its heads. The last three digits of the part number for your engine.
915 - 440 4BBL, manual transmission, heater, 375hp, Orange 1969
Next three are your transmission, and the three after that are the axle.
Next three are your axle assembly, and the three after that are the transmission.
*Edit to add your carb info since I had it handy: Carter AVS 4617 part# 2946 578 (78 appears on the broadcast in the "Carb" slot)*
My post #3 and #5. ThanksPost #5 makes a very good point regarding the 915 head castings. There are two versions, there low perf with the 1.60 exhaust valve and the HP with the 1.74 exhaust. It's possible some late '66 cars got some low perf 915's or maybe even some very early '68's. The '69 motors were well into the period when the 906 heads were used. One of my '68 440's was an April motor and had 906's.
Reading fender tags or broadcast sheets takes an awful lot of experience and access to factory info.
The closed chamber HP 915 is worth nearly a 1 point increase in CR compared to a 906 head. Pull the valve covers and look at the casting numbers on the head to see what they are.
Yes - agreed. That was errant on my part as to coding convention as we know it.In this instance the 915 is not the last three digits of a part number.
That’s what I always heard, throw the direct connection catalog and 915 heads on your car and presto, race car!Not from the factory, but it was a great performance upgrade in the day, as long as you didn't go with to much lift on your cam. It raises your compression almost a full point, like from 10 to 11 to 1.
I pulled an engine down years ago, and it had the small valve 915 on one side and the regular small chamber 383 head (516?) on the other side. I thought I had hit the jackpot with the 915 head until I saw it had small exhaust valves. This was the first I had learned of this abberation.
All factory 67 b bodies with 440’s had big valves. Most C bodies had small valves except 440 Super Commandos, 440 Magnums and 440 TNT’s.As a drag racer, I did just as you said. I did whatever level of porting I wanted and cut them for 2.14/1.81" valves. But that's a drag racer approach. If you are a resto person you look differently. As I understand it the small valve version was most common on the C body cars.
