I don't see much wrong here.
Those are not carbs. They are TBI, made to look like carbs. You can see the TPS on the side of the left carb throttle shaft.Picture of it in the dyno show carbs.
Was it dyno’d with carbs or FI?
Don’t know how to judge it not looking at some cam specs.
Exactly. I called them electronic carbs. Not really injection. TBI is close.Are those TBI's or MPFI with injectors at the end of each runner and throttle bodies?
Actually, I agree, TBI has the injectors positioned on top of the butterflies spraying fuel down onto them, these new tbi actually have the injectors under the butterflies injecting fuel into the airstream. So for lack of a better term, TBI or electronic carbs. Whichever, still injection at the base.Exactly. I called them electronic carbs. Not really injection. TBI is close.
The comparison of RPM's here IMO tells the whole story, the long rams are basically a choke point and done at 5k.If you click the link their standard 505 makes 650 TQ and 630 HP. So the long ram is up 50 lb/ft and down 40 hp. They do say their standard 505 uses CNC heads. Still pretty impressive torque numbers, plus the cool factor.
You can clearly see…..their” long rams”……I've got my own similar build going. I would also love to know what the cam specs were and how it was optimized if so for this motor combo. Being there were two OEM long ram versions offered, also be nice know which one is shown here. My guess is the higher RPM long Ram version. I personally feel TBI EFI does not solve the core issue with long rams mentioned in this press release, it mainly helps one tune around that core issue. I will be modifying my long rams for port injection, with the goal of the injectors being placed underneath for a more stealth look and what I believe is a better fuel path based on fuel chosen and to reduce fuel puddling partly by insertion into highest port velocity path. Because of space and packaging not sure I can achieve that location goal. I would also love to incorporate a staged single mini-injector in the plenum per long ram so I can wet the long ram and maximize air charge cooling when at full throttle. I will be using E85 and 12.5 CR. I do wonder how critical head port match up with long rams really is here with a big inch motor with a power curve/usage under 5K rpm.
The numbers reported here are very encouraging and welcomed. Nice courageous old/new school build.![]()
My doubt here was which version of long rams were they, they look in practice almost identical.You can clearly see…..their” long rams”……
Heavenly Horsepower Courtesy of Momma
Mopar !!
Think about it fellow Gearhead’s ….
These Were a product of the “ Chrysler
Firepower “ engineering teams …..in the 1960’s !!
Give Compliments to those talented individuals who broke the conventional molds then and now for thinking outside of the box &
Reaffirming the concept of “ Torque “ ….
This could catch on ya know with the hot rod
Community, now that we’ve got access to Fuel
Injection Technologies to enhance what’s been given. ….A couple of TBI’s ( throttle body injectors ) seem to function nicely wouldn’t you agree …..FI atomization evidently cures the “ fuel puddling” problems of old eh!
Remember… Momma Mopar engineered these beautiful intakes to fit under a stock hood !
On Chrysler 300’s after the Hemis in the early 60’s , Mopar gave the industry a “ Wedgie” of
Sorts … didn’t they !!
Imagine you’re “ stealth bomber B or C body
Makin a new age weenie millennial mobile look like a farm tractor at the next neighborhood red light romp with 700 glorious foot pounds
Of Mopar Muscles…. Then you can give all
You’re friends “ Wedgies” at will …..
They won’t know what hit em ….
Mopar2ya!!
John
Sounds like fun EH !!!!
Seems like a lot of duration for a motor that effectively tops out at 5K? I assume that is an off the shelf cam spec, not optimized for this unique application. HYD roller will also be my choice, as valve adjustment would not be fun.I was referring to "their" long ram engine versus "their" single four barrel engine. The cam specs listed are 242/248 duration 565/565 lift hydraulic roller.
The Heading says electronic carbs which I would presume are throttle bodies either sniper or the Edelbrock Easy StreetPicture of it in the dyno show carbs.
EFI has a setting called D cell fuel cut off which means it turns the fuel off coming out of the injectors when you let go of the throttle hence no fuel no puddling that's why I said it if you understand fuel injection you see the great advantages to that on this style of an intake systemMy doubt here was which version of long rams were they, they look in practice almost identical.
I am not convinced TBI EFI solves fuel puddling issues on long rams, does it reduce it, I am sure, but to what degree is unproven, and author indicates even with this EFI solution tuning was cumbersome, A very long mostly horizontal directional changing individual cyl long ram at low relatively engine speeds has a lot of area potential for puddling issues.
This is my long ram 413 creation in HS in 1969
