1. MAG GT
    MAG GT Member
    11
    0
    Aug 28, 2020
    Canada
    Local Time:
    10:17 PM
    HAS ANYONE DONE A A518 SWAP INTO A 75-79 B BODY?
  2. Darter6
    Darter6 FBBO Gold Member FBBO Gold Member
    4,492
    4823
    Dec 29, 2009
    Nevada
    Local Time:
    10:17 PM
    No, but did it in a 72 B Body. Lots of cross member work for sure, and floor work.It worked.
    • Agree Agree x 1
    • BeatersRus
      BeatersRus FBBO Gold Member FBBO Gold Member
      3,052
      4187
      May 31, 2015
      paying it forwards
      Local Time:
      11:17 PM
      the transmission Upper crossmember area will need to be clearanced.
      the lower will have to be Fabbed up using the original and extending it.
      Right where the body member is / is where the 518 gets bigger in the middle.
      the floor will need to be split and raised,
      this must be done extra carefully if you have a console shift car.
      you will need a shorter driveshaft.
      you will need a toggle switch setup to manually shift the 518/overdrive functions.
      for a 75-79 b body,it would be cheaper to install dual exhaust and put a better gear in the car,such as a 355 limited slip.
      if you do end up going to an overdrive,you will want anywheres from 373 to 410 gears to take advantage of the overdrive.
    • MAG GT
      MAG GT Member
      11
      0
      Aug 28, 2020
      Canada
      Local Time:
      10:17 PM
      I am doing a magnum swap with
      with factory EFI so the computer will
      handle the OD and lockup. We have
      emptied the A518 to use only the
      case to do the change fabrication work.Plan is to use 373 gears.
      Thanks for your reply
    • BeatersRus
      3,052
      4187
      May 31, 2015
      paying it forwards
      Local Time:
      11:17 PM
      heres a link to the A body forum which is also one of Joeys sites.
      you might find some good info about the course you are taking,ie,
      using the efi factory setup.
      personally,ive already went thru this and decided it was easier to 4bbl intake and carb it,
      rather than use all the original wiring and computers.
      bets of luck whichever direction you choose.
      https://www.forabodiesonly.com/mopa...u-on-a-toggle-or-auto.453010/#post-1972804824
    • MAG GT
      MAG GT Member
      11
      0
      Aug 28, 2020
      Canada
      Local Time:
      10:17 PM
      Thanks For the link
      I am looking at the EFI more for
      convenience of being able to get
      in car after sitting for months and
      have it run consistent. As for the
      wiring I did my friends 65 Comet
      with a 5l out of a 88 Crown Vic
      and it worked out.
      Thanks again
    • MAG GT
      MAG GT Member
      11
      0
      Aug 28, 2020
      Canada
      Local Time:
      10:17 PM
      I seen a lot of pics from older B bodies,
      do not know if things changed when
      the car was redone from 1975 to 79.
      Not much info about these years.
      Would the cross member be the same?
      I seen on one site that they sell a
      cross member for A518 for older
      B bodies.
      Thanks for you input.
    • Darter6
      4,492
      4823
      Dec 29, 2009
      Nevada
      Local Time:
      10:17 PM
      Yes cross member is different. 75-79 rubber mounted to frame.The do make a poly mount kit. I used it in my 79 300.
      Changed the front K frame rubber mounts to poly at the same time. I believe it was ProThane.
      Also the floor pans will differ because if cat converters being used those years.
      3.73 gear is what I used.
    • Fury Fan
      Fury Fan Member
      17
      15
      Sep 9, 2020
      Indianapolis
      Local Time:
      11:17 PM
      If going with a Magnum (5.2 or 5.9?) have you considered using an A500 and beef it up a bit? It is shorter, so it moves the OD section further forward, possibly into the wider section of the tunnel. Might be more expensive to build the trans but less fab work? You'll also get teh deeper 1st and 2nd gears with it.
      The A500 came only behind V6s, but the 3spd A999 was used in 318 copcars and 1/2-ton trucks, so the 'lil trans has some heritage of taking some abuse.
    • MAG GT
      MAG GT Member
      11
      0
      Aug 28, 2020
      Canada
      Local Time:
      10:17 PM
      I have the A518 already and my friend is a trans re builder
      is doing the work only for cost of parts. We emptied the case
      so will try to fit into car first to see how much modification
      is required. I will bring up the A500 to him and ask his opinion.
      Thanks for your input.
    1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
      By continuing to use this site, you are consenting to our use of cookies.
