ron luks
Aerospace vacuum pump assy, complete ready to bolt in with bolts. Set up for big block mounting on passenger side without motorplate. Aerospace does not sell mounting brackets for mounting without motorplates, I have combined aerospace pump mount with jz mount to install on passenger side..if you have a motor plate it can be used also. The pump was just rebuilt, new bearings, orings, carbon fiber vanes, included is pump mounted vacuum control, overflow tank with kn filter, belt, one #12 hose, crankshaft pully and everything needed to bolt to crankshaft. The only things needed are a short -12 hose and a -12 fitting in the valve cover.
This is a great buy, complete assy. $800.00 delivered to the lower 48.
Thank you Ron Luks
Thank you Ron Luks
