General23cmp
1969 Satellite. Newly rebuilt PS box by a pro (my old box was rebuilt).
The only things I removed was the column and the pitman from the box when doing this. No steering linkages were touched.
Installed it.
Steering column can really only go on one way (or be upside down). The pitman arm does not appear to have any indexing teeth, so it could go on "anywhere". I did mark the pitman prior to removal, so I put it back on where it was prior. Now my steering wheel points to about 1-2 o'clock to go straight down the road. If I move it to 12 o'clock, the car will go left. I did try moving the pitman one tooth over each way, and it is way off when I do that, so I feel I am on the right pitman tooth.
Is it common to need an alignment after a tighter, newer box is put on a car? I could see an instance where my old sloppy box might have made it look like I was pointing straight to go straight, and the alignment was set accordingly. Now with the new box, the "slop" is gone and the old alignment is showing this lack of "slop". Is this possible? Other thoughts?
Installed it.
