AMD trunk floor extensions.
Have not used these but had to get a floor pan from them. Good products. If you need to trim some, easier than making something yourself.
That trunk extension is from a 67 Belvedere. The trunk floor pan and the wheelhouse are the same for my charger and the belvedere. I guess it would need some finessing where it gets attached to the lip of the 1/4 panel.
It might require more modification than you think. The 66-67 Charger extensions are wider at the front than coronets, of the same years. I have no knowledge of how the plymouth ones might differ.
I bought the AMD 67 Plymouth extensions to use on my Coronet. I've been told the only mod necessary is to the leading edge to account for the different angles between the wheel openings in the 1/4 panels. Haven't actually installed them yet, so I can't say for sure.
The trunk floor and inner wheel houses are the same so those attachment points should definitely match up.
Also not sure if Charger is different than Coronet.
Joe Phillips Restorations makes the ones for Chargers. A supplier here brought in b body ones that were for a Coronet. Way too much work try and make the AMD ones fit a Charger. Joe also makes lower quarters and full quarters for the Chargers.
Thanks. I just sent him a message on Facebook. Looks like he makes nice 1/4 panels as well.
I just googled that guys name and two YT videos popped up. Holy smokes that dude is talented....
