- 12:22 PM
- May 29, 2013
I'm thinking ahead here. When you install a vinyl roof on a Coronet, how is it held / attached along the drip rails? I'm sanding away on the car and was noticing the sealant used without the vinyl. So do you remove the sealant and the vinyl becomes the seal along the edge? Then I presume it is glued along there, but does the chrome trim go over vinyl or does it stop in the rail? I don't think the chrome trim would have enough clearance to go over it. Any and all info (even pics!) is appreciated.
Thanx F.B.B.O.
Thanx F.B.B.O.
