cuda Hunter
1974 charger 318
No spark
I have changed the following
ECU
Coil
electronic voltage regulator
ballast resistor
Car has a bypass installed for the starter due to the interlock system.
pretty right?
I've set the reluctor to .08
Tested the resistence on the pickup coil and it's 325
Coil is not collapsing the field noted by a test light no strobing from the negative of the coil
I hooked up a jumper wire from the positive of the battery to the positive of the coil and still got no spark
ECU wire test.
Dark blue with yellow stripe to number 1 on the ecu.
Key on position- 10.5
Key on run position 8
Key on run and starter button pushed - 6.5
I reset the interlock system and still no change
I disconnected the interlock system and still no spark
I'm assuming that I am going to have a grounding problem that is not allowing enough volts to make it to the ECU.
Ideas welcome
No spark
ECU
Coil
ballast resistor
pretty right?
ECU wire test.
Ideas welcome
