Atomic Wedgie 1st run of 14'
wedge5
10:32 PM
Central IL
Finally got the car down the track. Only made 1/8th mile passes. Best 6.736 @101.91 w/ 1.484 60ft
Made 6 total passes most being 6.74-6.76 @101.95 w/1.50 60ft
I didn't adjust anything i.e tire pressure, shocks setting. I just wanted to get a base line and get the car down the track. It was cold out so the track wasn't the best. The sun went under after my 1.48 60 ft pass and the 60ft times went down so I loaded up. I think with better rear shocks, tire pressure and hitting shift points better would help. Hopefully I can get to the track 2 more times before the weather gets too cold here so I can test some more.
Nice passes
Sweet, it sounds like you had a good day, hope you had fun too...
looks like a 10.50-ish 1/4 mile pass {6.73 x 1.57* (1/8th mile to *1/4 mile conversion) = 10.56}
Congrats on getting some passes on it. Sounds as if all went well. Sounds like about 10.50's as my 63 runs 6.80's in the 1/8 at 100 mph with a 1.50 sixty which is 10.70's in the 1/4. Ron
