Flint
Fluid damper from 440 source. Looks like a problem to me ? Yes it just slides on the new stroker crank. Hopefully they will replace it. That’s the way I received it out of the box. Anyone have this issue?
Crank is spot on.Is the damper too big or the crank too small?
Then why do I always need this?It's not a press fit, the damper is clamp loaded with the bolt. Torque the bolt to specification and your good to go. 440
Pontiac is relying on the bolt to mate the dampener to the crank. Just another shortcut to make assembly on the line easier imo and is another reason I don't like GM products. And you're right on the Mopar bolt size. Btw, my 74 Dodge pickup with a /6 didn't have a bolt.Pontiac dampeners are a slide on fit, not press fit. What keeps it tight is the 160 ft/lb of tq on the bolt, which is 5/8". Never a problem as long as the tq is correct. I do not see a problem in this case. I believe the Chrys bolt is 3/4" thread, so should be torqued to a higher value.
So, it's almost .002" tight? That's pretty snug.....imo, that's way more than a slight interference fit. I'm a machinist too.Well the instructions that came with it specify a slight interference fit. I’m not a pro engine builder but have done a dozen or so over the years. Plus I worked in a machine shop most all my life. I posted the directions. I can see it shearing the key.
It’s the other way around.It wouldn’t slide on otherwise, does anyone actually read?So, it's almost .002" tight? That's pretty snug.....imo, that's way more than a slight interference fit. I'm a machinist too.
I read it but got it backwards.....my bad. And I don't believe I would run that.It’s the other way around.It wouldn’t slide on otherwise, does anyone actually read?
Thanks. I don’t see any evidence of it being a honed finish on the bore.I read it but got it backwards.....my bad. And I don't believe I would run that.
