Ya to me it looks horrible to me. I’d send it back too. KimI got a RA number from 440 source with no issues so hopefully the next one is good.
Agree. My neighbor has a Sunnen hone that we hone them on.You're supposed to hone the bore of the Damper, not reduce the diameter of the crank.
Next time you try and fit someone else's damper on that crank fit, it will be loose.
I have done gage R&R studies on od mic measurement on seasoned machinists. The results were scary bad. I'm not saying machinists can't measure. Its just that many were never taught the basics and are not good at it. Some excel at it.I'm a Machinist and you have to develop a certain "touch" when you are setting your Mic from a Gage block.
Then you need to remember that same force when you measure a part. Dial bore gages take that out of the
equation, but not everyone has one.
Don't get me started on calibration labs. We don't get along. I cannot count how many times I found calibration labs have a TUR (total uncertainty ratio) below 1, which means that item they are calibrating is more accurate than what they are calibrating with. I have many many stories. I actually got a quality manager removed from his role at a large manufacturer because of this - this started it but his attitude about the subject finished it.Also how many people actually had any of their measuring equipment go through a PMEL lab to check the accuracy.It’s not just, oh I checked zero.
I always just delt with USAF PMEL. They would check my privately owned equipment for me.Don't get me started on calibration labs. We don't get along. I cannot count how many times I found calibration labs have a TUR (total uncertainty ratio) below 1, which means that item they are calibrating is more accurate than what they are calibrating with. I have many many stories. I actually got a quality manager removed from his role at a large manufacturer because of this - this started it but his attitude about the subject finished it.
The reason the labs get away with is is because the folks hiring them generally do not understand metrology and do not hold them accountable. The expectation is very low - send them the instrument for calibration and accept as gospel what comes back.
