I had my block machined about a year ago and had cam bearings installed at that time. I started assembling it last month and discovered the cam is too tight, will not go into the journals. The bearings are Dura-Bond High Performance Coated Bearings PDP-17T, I tried the cutter cam idea since they were probably coming out anyway and had no success. Ordered new bearings and talked to the shop I was going to have look over my Eddy RPMs, they use a different cam bearing installation tool/method and sounded like the quickest way to proceed. Just got done talking with him and found out he is having the same issue. He says the bearings fit on the cam journals, the block journals measured out fine and the bearings still measure fine after installation but the cam will not go in all the way. He says its as if the journals need to be align honed but he has never had to do that before. Anyone ever see this? Any ideas how to fix it? I hate to think I might have to eat the $2K I've already put into this block.
