cam help for heavy wagon
fullsizewings
New Member
6:40 PM
sweden
guys, i have a old 1961 newyorker wagon under restoration, my enginebuild looks like this
400 block , 413 crank, 440 rods, icon 12 cc dish pistons, 78cc tfs 240 heads, edl rpm intake Hly-750 dp
1 3/4 headers, 440pound, 26" tires, 3.23 gear, stock converter, Power brakes,
compression is approx 10:1 , what hyd flat tappet cam would you guys use in such Heavy car? and will it see 400+hp with a cam that works with this "Tank"
I think you are putting the right components together and Monday I recommend calling a cam manufacturer for their recommendation.
Mike
A cam that makes good power at lower rpm's and takes advantage of that compression. RV grinds come to mind. 440'
Yes i also belive in an RV or Marine grind, I lean to call the Lunati Tech This is a copy from their website
Advertised Duration (Int/Exh): 262/268; Duration @ .050 (Int/Exh): 220/226; Gross Valve Lift (Int/Exh): .475/.494; LSA/ICL: 112/108; Valve Lash (Int/Exh): Hyd/Hyd; RPM Range: 1400-5800; Includes: Cam & Lifters (#71977PR-16)
Any Heavy hauler mopar guy using this cam
