Camshafts for Chrysler
wyrmrider
10:34 PM
los angeles
This last edition covers performance grinder's cam sorted by duration at .006 lift
and comparable grinds where .006 lift data is available. I do have cam-doc data from years ago but can't find it.
Comp, Lunati, Howards, etc are following
Crane, Cam Dynamics and the Production cam grinders Melling, Sealed Power, Elgin, Wolverine
who rate by the SAE method or .004 are here:
https://www.forbbodiesonly.com/mopa...fsm-cams-compared-to-detroit-grinders.154324/
Factory, Mopar Performance, Direct Connection and Engle and Isky megacams- who rat duration around .008 tappet lift are here
https://www.forbbodiesonly.com/moparforum/threads/direct-connection-cams.154098/
.sorted by duration @006 lobe lift XE SFI etc = Comp VD=Lunati HM Howard
bvvc to identify race only grinds and spring requirements
do not always use the one with the most lift
lift _.006 .050 .200 lobe grind#
.432 250 206 117 XE 5440 XE250H 600-4800 19 51 16 64
.454 250 208 VD 60300 also used for AMC
.452 252 208 121 XFI 5082
.473 252 206 126 HM2063164A
.454 [email protected] [email protected] [email protected] Jones special
for comparison DC 260 is 269 @.006
@.275 lobe lift Jones is 64 @.275 when DC 260 is 42
about a 50 % difference
at .004 or SAE Jones is 264 and DC 260 is 284 That's about a 10 degree earlier intake close- IC is really important for low compression motors
.479 255 208 128 HM2083190 Used for AMC
.447 256 212 124 XE 5441 XE256H 22 54 20 68
.454 256 213 VD 60301 also AMC 0701 1000-5000
.458 256 212 125 XFI 5083
.483 157 210 130 HM2103219
.468 260 216 129 XFI 5084
.494 261 214 134 HM2143294A
494/506 261/267 214/220 110/106 .904 Howard grind
.462 262 218 130 XE 5442 XE 262H 1300-5600 int 25 btdc 57 abdc Ex 69 bbdc 21 atdc
.473 262 218 131 XFI 5085
.498 263 216 136 HM2163318A
.482 262 217 134 . X4X4 5903
.475 262 220 VD 60302 1400-5800
.502 265 218 138 HM2183345A also used for AMC
.488 266 221 138 . X4X4 5904 MI 23.5 (11.3/12.2)
.506 267 220 140 Howards 721141-08 1600-5400 ( HM2203372A intake lobe)
{ 506/506 267/267 220/220 108/104 smallest .904 shelf cam 1500-5400 wants headers }
.477 268 224 137 XE 5443 XE 268H MI 22.9 (11.1/11.8) 28 60 26 74 1600-5800
.488 268 224 138 XFI 5086 MI 23.1 (11.2/11.9)
.494 268 226 VD 60303 AMC 0703 1800-6200
.533/.552 284/292 242/252 Lunati MOPAR 273/360
.430 206 Howard American Muscle 1400-5000
.434 207 Crane 967981 Blueprint
.430 269 212 115 DC 260 early from cam doc
.430 269 221 DC260 late 2001 catalog
Exhaust lobes are not shown on shelf cams
Comp XE and XFI are .842 lobes XE4X4 are .904 lobes note less intensity ( and I suspect more area)
and would be easier on the valvetrain
Comp shelf cams intake closed @.006 shown I bold would change if you changed centerlines or LCA
intake closed point would be very similar with other cams at same intake duration
HM Howard VD Lunati Voodoo all “shelf cams” if ex and lca fit your needs
recent check confirmed eventhough Lunati exactly same lift, duration and .050 as for a chevy the MOPAR had more duration at .200 and I suspect meaningful more area “under the curve”
If you need Lunati .200 call
Jones asymmetrical max area lobe is extremely fat 250-275 lift
compare Howard universal vs 904 at 260 duration @.006 about 8 bigger @.050
Howard Street force 420/444 259/269 205/215 112/108 not .904
Thank you for the info. Always more info better build
That list only goes up to the DC 260 area and I extracted it from my spredsheet basically for input into the stock late 400 and 440 and low compression small block builders-
there is a wide difference in seat timing available
next Dodger game I'll take a crack at the larger cams
