Can heads and studs be replaced with motor in car?
Engine, Trans & Driveline
  1. YellowDodge67
    YellowDodge67 Well-Known Member
    99
    41
    Jun 30, 2010
    Glen Burnie, Maryland
    Local Time:
    10:06 PM
    Looking to replace my head gaskets and install head studs on my wagon. Can the cylinder heads be removed and re-installed with head studs with the engine in the car? It looks like it may be tight. Can the heads be set in place and the studs be threaded into the block afterwards? 440 in a 67 Coronet.
  2. 747mopar
    747mopar FBBO Gold Member FBBO Gold Member
    11,120
    12300
    Oct 30, 2012
    ohio
    Local Time:
    9:06 PM
    Yes and yes.
    • Agree Agree x 6
    • Thanks! Thanks! x 2
    • YellowDodge67
      99
      41
      Jun 30, 2010
      Local Time:
      10:06 PM
      Thanks, I was going to pull the engine out to do it "right" but I just don't have the room to pull everything apart right now.
    • beanhead
      beanhead FBBO Gold Member FBBO Gold Member
      3,673
      5502
      May 18, 2014
      Wackyfornia
      Local Time:
      7:06 PM
      Biggest hassle in my opinion anyway is pulling out the headers, if you have them..
      • Agree Agree x 1
      • YellowDodge67
        99
        41
        Jun 30, 2010
        Local Time:
        10:06 PM
        They're forward facing turbo manifolds and luckily they aren't too bad to get off.
        • Like Like x 1
        • 747mopar
          11,120
          12300
          Oct 30, 2012
          ohio
          Local Time:
          9:06 PM
          Now you've got my attention, a turbocharged Wagon!:xscuseless:
          • Agree Agree x 3
          • fbs63
            fbs63 Well-Known Member
            177
            96
            Feb 5, 2017
            Lowell, Indiana
            Local Time:
            9:06 PM
            ARP head studs have a 3/16" hex broached in the end so you can set the heads and put the studs in after.
            • Like Like x 1
            • YellowDodge67
              99
              41
              Jun 30, 2010
              Local Time:
              10:06 PM
              That's what I was thinking, I've seen the diesel guys do it that way.
            • YellowDodge67
              99
              41
              Jun 30, 2010
              Local Time:
              10:06 PM
              [​IMG]
              • Like Like x 4
              • Thanks! Thanks! x 1
              • YellowDodge67
                99
                41
                Jun 30, 2010
                Local Time:
                10:06 PM
                [​IMG]
                • Like Like x 4
                • Grabbergreendream
                  Grabbergreendream Well-Known Member
                  111
                  51
                  Jul 1, 2017
                  Ashtabula Ohio
                  Local Time:
                  10:06 PM
                  No wonder it needs head gaskets, lol!
                  Nice ride! Bet its a blast to drive!
                  • YellowDodge67
                    99
                    41
                    Jun 30, 2010
                    Local Time:
                    10:06 PM
                    It gets some looks lol
                  • zyzzyx
                    zyzzyx FBBO Gold Member FBBO Gold Member
                    832
                    682
                    Aug 5, 2011
                    Lisle, Illinois
                    Local Time:
                    9:06 PM
                    Jeez, That looks fantastic! Uh, back to the head studs. If you're using ARP head studs to seal
                    the heads better and take advantage of the higher torque numbers you can get to, are you
                    forgetting that the added torque will distort the tops of the cylinders even more? The cylinders
                    should be honed with a torque plate installed on the engine at the specified torque of the studs.
                    I'm guessing around 110 lbs/ft. If you're running anything over 12lbs of boost I would think
                    O-ringed block would work great and never fail you. You've done a lot of nice work there!
                    • Agree Agree x 1
                    • YellowDodge67
                      99
                      41
                      Jun 30, 2010
                      Local Time:
                      10:06 PM
                      The head gaskets and studs are more of a temporary fix. I'm not running high levels of boost because the motor is stock. Unfortunately I'm pretty sure I had a waste-gate issue and blew the stock head gaskets out. New motor is still in the works and I don't have the finances to complete it the way I want to right now, so instead of half-assing the new one, I'm trying to keep this engine alive so I can still drive it around and enjoy it, even at low boost.
                    • Grabinov911
                      Grabinov911 Well-Known Member
                      558
                      236
                      Jan 27, 2012
                      Southern California
                      Local Time:
                      7:06 PM
                    • dvw
                      dvw Well-Known Member
                      3,890
                      4973
                      Feb 16, 2010
                      waterford mi
                      Local Time:
                      10:06 PM
                      Too much timing will kill small block head gaskets. Where did it blow out at? We've run 21lbs on small block with Cometics and studs no issue. Only 21 degrees total.
                      Doug
                    • YellowDodge67
                      99
                      41
                      Jun 30, 2010
                      Local Time:
                      10:06 PM
                      I'm not sure where it is blown out. Just seems to be pushing coolant, smoking some and overheating quickly. Can you run cometics without refinishing the head and deck surface? I thought I was told cometics require a super smooth finish ( I could definitely be wrong lol)
                    • MarPar
                      MarPar MeatMan FBBO Gold Member
                      12,136
                      17979
                      Nov 21, 2008
                      In GTXtacy Illinois
                      Local Time:
                      9:06 PM
                      • Like Like x 1
                      • Agree Agree x 1
                      • dvw
                        3,890
                        4973
                        Feb 16, 2010
                        waterford mi
                        Local Time:
                        10:06 PM
                        Yes Cometic use a smooth finish. I had good luck with Felpro after learning about the timing with my roots blown Volare. With proper timing and studs 13psi was not an issue. However it never steamed or lost water when it blew a gasket from detonation. Either between cylinders 3 and 5 or at the top of #5 into the valley. When it was in the valley it would pull oil and smoke. My sons turbo car at 21psi has never hurt a gasket (Cometic and studs).
                        Doug
                        • Agree Agree x 1
                        • YellowDodge67
                          99
                          41
                          Jun 30, 2010
                          Local Time:
                          10:06 PM
                          I'm not pulling the motor to get decked with a smooth finish, so cometics wouldn't work for me right? And if I used one with a factory compressed thickness I shouldn't have any problems with my pushrods right?
                        1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
                          By continuing to use this site, you are consenting to our use of cookies.
