The simplified explanation;
There are several factors at play here; first the original 71’ specs are primarily set-up to minimize certain gases present in the tail pipe emissions over any true performance or drivability concerns. The limiting factor is the total mechanical advance set-up in the distributor. On the big blocks around 34-35 degrees is the upper limit before detonation/pinging occurs at WOT. This includes initial and centrifugal crankshaft degrees, vacuum advance disconnected. Without an actuate degree tape you will need a timing light with adjustable timing to verify total advance. The original distributor for that motor will something like 28-30 crankshaft degrees built into its cure. Sounds to me like your motor likes somewhere around 10 initial, you will need to modify the limits of your distributor curve to something around 24 crankshaft degrees total to allow the advanced initial without exceeding the total limit. Later Mopar Performance and aftermarket distributors are designed with adjustments to the limit, original distributors can be modified, requires welding and careful filing of distributor parts. Ideally the use of an old-school distributor machine is needed, but can be accomplished without.
Short of messing with or replacing the distributor, find a way to set the timing at total mechanical advance, vacuum advance disconnected, around 34, test drive for no pinging WOT, make your idle adjustments with whatever initial you are left with.
