Well, after sitting for 4 months I went to start the 62 Belvedere, battery was dead and when I got it started after priming the carb it ran like crap. A few dead cylinders due to flooding so....I bought a gasket kit (Eddy 1405) and rebuilt it.
As much as people rave about efi, the simplicity and value of an Edelbrock carb is unmatched. Took it all down, cleaned all passages and put it back together with a $14 gasket set. I found the more expensive complete set is unneeded most of the time. Also purchased a new accelerator pump.
There was crud in the bowls and floats looked nasty. Cleaned up and bottom half back together.
Floats were way off so I adjusted them. There are also 2 inlet screens to clean.
I also bought new NGK plugs and new 7mm wires.
