Aron Gleason
Well I found out I had to turn the idle screw down from 4 turns out down to 1 turn out on the wagner pcv valve. Everything else is the same, in fixed orfice mode with the high vacuum spring in, cruise screw flush. Afrs are better at cruise but I still have a really bad stumble from cruise to wot. My afrs will jump to the high 16's.
