Change rear lightbulbs on a 1975 charger se
John Molands
10:06 AM
Halden, Norway
Hi!
I am gonna change the lightbulps in my rear lights but I have stumbled onto an issue.
Am I supposed to screw the hole lamp off the body and then split it to change the lamps or is there another way I have not thougt of. maybe take the bulb and the holder out of the lamp from behind or something?
should be removable holders
open trunk look at inside.
twist light bulb holders gentlely and pop them out of plastic housings.
no,you dont have to remove the housings to swap bulbs.
