ToddMcF2002
Hi folks 69 GTX here with 70 style voltage regulator. I just replaced the regulator because it refused to send any signal to the field wire (green). The blue wire is definitely getting power. The case is definitely grounded. If I jump the field wire the alternator charges, ammeter shows it charging.
1st pic: Here is the regulator with the jump wire to field - its the only way I can get the alternator working
2nd pic: The single field alternator
3rd pic: The case ground. Its definitely grounded
