I’m going to due the electronic ignition conversion to a new under hood harness on the 67 Coronet RT 440cid.
I don’t like the butchered mess of the old harness so I’d like to get this right. I searched our forums and was wondering if this photo depicts the best wiring install. I’m using a 4 pin Mancini module.
So I understand the operation I will be piggybacking directly from the start relay yellow to side of the ballast that has the dark blue and brown leads?
The single blue wire on the ballast will get a piggyback with the blue yellow from module harness? Still leaving connected to ballast?
Does the ballast remain functional with this system?
Appreciate the help as always
Dan
Dan
