Clear coat recommendations
70rrclone
9:23 PM
La Grange Ky
I am finally getting stuff together to paint my 70 Satellite. I am using Cromax base coat. The local paint store says chromabase 7400s is what is commonly used in the local area. This stuff has a 1 min flash time and can be buffed in 45 mins. This seems fast especially for a complete paint job done in a garage. Are there better compatible options out there? The car will be outside a lot so I need good uv protection.
Shane
IMHO --
7400s is more of a production/collision type clear --
"A three-component, clearcoat designed for panel and multi-panel repairs. It is ideal for facilities with air dry conditions that require fast assembly times. 7400S™ can be polished within 30 minutes."
=== from website
We do not use Dupont clear on our cars - but do on occasion use Dupont base coat (does a exceptional job color matching for Chevrolet)
Think a more standard Cromax/Axalta clear that is used for an all-over paint job would be a better choice, can use fast/slow hardeners to get the desired effect.
Find a clear with high solids, will be the "clearest" and do a much better job with UVs.
Bill
Axalta 7900s ChromaClear. It’s worth the coin.
That 7400 with a one minute flashtime- you won’t have enough time to get around the car.
Thanks for the info! I'll check into the 7900s today.
Shane
I just used some today!
