Clutch hose problems to tr 6060
70restob
1:11 AM
kansas
How's everybody? Having trouble with clutch hose blowing off the connection to tr 6060 trans 6 speed? We are running a 6.1 with the tr 6060. We are using the factory pedals and willwood clutch for master cylinder? Using factory clip just blows off?
I had that problem also. I cut the stock 6060 fitting and attached an AN4 teflon fitting, then you need a metric adapter (i think its 1.5 on the wilwood side) and AN4 on the other.
Another thing, my 6060 came from a 2014 Challenger. It doesnt have a bleeder. You have to do the mighty vac thing: stick a pointy tip into a full reservoir and vacuum until it stops, then pull it out so fluid flows into the line below.
Havent been on for a while thank you so much. This car will be on the discovery channel monday october2 after diesel brothers she's a runner!
Good evening 70restob, I'm building a 1968 dodge charger, I have a 5.7 hemi with tr6060. I wanted to know if you had any photos of the transmission crossmember you used?
