Anyone know cfm's needed too cool for a mild 440 in Florida?
A lot. lolAnyone know cfm's needed too cool for a mild 440 in Florida?
The more the cooling you cant go wrong the tstat takes the rest up.I think Hemi 354 has it right. At least 3000 cfm.
26" radiator w 18.5" factory 7 blade fan, fan clutch and factory shroud. If You have a/c. A 1.3:1 water pump to crank pulley ratio and correct pump, w/out a/c, a 1:1 pulley ratio and corresponding water pump. 180° thermostat.
