Cooling C FM
26" radiator w 18.5" factory 7 blade fan, fan clutch and factory shroud. If You have a/c. A 1.3:1 water pump to crank pulley ratio and correct pump, w/out a/c, a 1:1 pulley ratio and corresponding water pump. 180° thermostat.
I think Hemi 354 has it right. At least 3000 cfm.
This is exactly my setup, 499ci stroker in Texas. All stock except for the 180F thermostat and aluminum water pump. Never overheats.
