Custom backspacing
Racers Hangout
  1. 65 Ply
    65 Ply Active Member
    27
    6
    Feb 25, 2009
    Minnesota
    Local Time:
    8:51 PM
    Does anyone now if you can get custom backspacing for American Racing Torq Thrust D? In particular, I'm looking for 15"x10" with 5.75" backspace.
    thank you
  2. HEMI-ITIS
    HEMI-ITIS STREETER on LI FBBO Gold Member
    12,291
    15057
    Dec 14, 2008
    Long Island,New York
    Local Time:
    9:51 PM
    You might end up with a 5.5 BS and .25 inch spacer.
  3. Budnicks
    Budnicks You Can Just Thank Me Later FBBO Gold Member
    56,223
    63918
    Jan 16, 2011
    NorCal Sierras
    Local Time:
    6:51 PM
    You can try Google Search "Stockton Wheel" here in Calif., they will do all most any backspace & diameter wheel rim combo you want, they can remove the hoops/outer rims & install new if necessary, if that's the centers you like, they may even have those centers possibly... call them they are in the phone book & on the web...
  4. 65 Ply
    27
    6
    Feb 25, 2009
    Minnesota
    Local Time:
    8:51 PM
    thank you Budnicks. I used Stockton for steel wheels in the past, but did not think to use them for one piece aluminum.
  5. Cranky
    Cranky Henchman #1 Staff Member FBBO Gold Member
    24,068
    22789
    Dec 4, 2009
    Down southeast Taxas
    Local Time:
    8:51 PM
    If you do that, wouldn't you end up with 5 1/4 back space?
    Don't know how they are these days, but several years ago a buddy used them and it took 3 times and they were still not right and had to use 3/8" spacers. The first time was way off, the second time they came back with Ford centers and the 3rd, we just made spacers and gave up.
  6. HEMI-ITIS
    12,291
    15057
    Dec 14, 2008
    Local Time:
    9:51 PM
    Cranky,adding spacers increases the back space:happy7:
  7. 65 Ply
    27
    6
    Feb 25, 2009
    Minnesota
    Local Time:
    8:51 PM
    for my application I agree with Cranky. Spacers will move the tire closer to the fender (which I'm trying to avoid).
  8. HEMI-ITIS
    12,291
    15057
    Dec 14, 2008
    Local Time:
    9:51 PM
    If my old memory serves me right,a 5.5 B/S is one of the standard.You calculated 5.75.So if the tire is too close to the inside,a spacer can be used.If you need LESS B/S,you need different rims.I use 2 different size spacers for my street meats for the fit I need.
  9. Cranky
    24,068
    22789
    Dec 4, 2009
    Local Time:
    8:51 PM
    I thought increasing the back space moves the inner wheel rim closer to the spring or frame?
  10. HEMI-ITIS
    12,291
    15057
    Dec 14, 2008
    Local Time:
    9:51 PM
    To measure the B/S on a rim,set it face down and lay a flat bar accross the rim.Then take your measuring device and measure from the mounting surface to the flatbar.That's the backspace:grin:
  11. Cranky
    24,068
    22789
    Dec 4, 2009
    Local Time:
    8:51 PM
    Yup. Wheel back space doesn't change but if you want less to the inside, add a spacer. No?
  12. HEMI-ITIS
    12,291
    15057
    Dec 14, 2008
    Local Time:
    9:51 PM
    Yes,a spacer will increase the backspace:grin:
  13. iraqivet01
    iraqivet01 Well-Known Member
    1,303
    199
    Oct 10, 2009
    Sapulpa, OK
    Local Time:
    8:51 PM
  14. 65hemi
    65hemi Well-Known Member
    914
    1663
    May 21, 2011
    Winnipeg, Manitoba
    Local Time:
    8:51 PM
    I think 3.75" is the standard BS for the 15 x 10 Torq Thrust Ds. That's what is currently on my 65 Belvedere. Springs have been moved in 3" and an a-body width diff is in the car.
  15. HEMI-ITIS
    12,291
    15057
    Dec 14, 2008
    Local Time:
    9:51 PM
    You right,I got it backwards:icon_confused:See what happens when I stay up past my bed time:confused2::icon_redface:
  16. dartjnky
    dartjnky Well-Known Member
    67
    40
    Jan 24, 2010
    So Cal
    Local Time:
    6:51 PM
    Wheel BS
    Hi 65 Ply-
    65 hemi is right they come 3.75"... but you can pretty much get what you want (within reason no less than
    3.75"). I just ordered a set from Jegs 15 X 10 w/4.5" BS.. additional $60 ea wheel for the custom BS. They also want 6 weeks manufacturing time (I think it will be closer to 8 with holidays). Just got an email from them, will not have my fronts 15 X 4.5's until 1-17-12. Oh well... I will have them for next year.
    Good Luck-
    Glen
    D/J
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    By continuing to use this site, you are consenting to our use of cookies.
