Frankb
I would like to cut a 3/4 inch hole, on forward and aft side, of passenger side torsion bar mount bracket to run a fuel line. Currently my lines are in the factory positions. Car is Sniper EFI so there are two metal lines. I have AN fittings with -6 steel hose for connections at tank and at carb. Car has subframe connectors and torque box, front and rear. Forward end of passenger sub frame connector is welded to torsion bar aft mount bracket. New lines would run down inboard side of passenger frame connector but I need a hole in the torsion bar mount bracket to make this work so new line could go through the torsion bar mount bracket. Will doing this weaken the mount bracket to any noticeable degree? Any at all? Or will the mount buckle at the first burn out??Car has 512 wedge and makes a lot of torque. I want to do this for a cleaner install of the fuel lines.
Frank
Frank
