HEMI RR
Planning on a 8 3/4 to Dana 60 swap on a 70 Roadrunner. The presently installed brake lines and hose are in good shape so can they be reused from the 8 3/4 to the Dana? Or, are there some changes needed?
Ok thanks. The lines on there now are about a year old. I could not find parts online at the 3 major auto parts stores. I checked the Classic Industries book and turns out 1970 is the only year the Dana and 8 3/4 hard lines and rubber hose are the same. My Dana is a 1968 so I suppose all I need to do is ensure the T block mount is located in the same place. Thanks for all the help you guys are so informative.
My rubber line is about 14.5” long for my Dana 60 In a 1969 Belvedere. The distribution block is on the drivers side near where the axle tube joins the Center section of the Dana. I’m not sure on the year of the Dana though. I have a Raybestos part number somewhere if you need it.
The steel ones should work, you may need to tweak here and there a bit.
