Dash cluster 1969 superbee
I'll add to the question if I may. Did 68 use the same paint?
'68, '69, '70 all the same. Check out the restoration threads on this forum. Somewhere there is also a cluster restoration thread I can't find, it maybe over on dodgecharger.com
That said, if you are only touching up a spot and don't want it to stand out... the only real option is to buy a cluster of different paints and do test pieces to compare to your panel.
Flat black or matte black? You don’t want any glare at +100mph!
