Dash lights and dome.
Russ Hood
4:19 AM
TN
My dashlights and dome light haven't worked since I bought the car about 3 years ago.
In December I installed a new dash wiring harness. Didn't change anything. So this evening after work I started checking it. Found the dome light bulb was blown and replaced it with a new one that will not go off. I checked the fuses and the top one 3amp there is no power. I checked with headlights on and ign switch on. Nothing no power.
So I'm guessing the dash dimmer switch is the root of the problem?
dadsbee
5:19 AM
Midland Ontario, Canada
Dimmer rolled all the way to the top turns it on... or a shorted out door switch. (or wire to one touching ground).
pnora
5:19 AM
Ishpeming, Mi.
While you could have a bad switch it does not control the dome light. Yes it can turn the light on by completing the ground but that's about it. I would pull both door jamb switches and see what it does. If the yellow wire is grounded anywhere the light will stay on.
Russ Hood
4:19 AM
TN
Thanks I will try that tomorrow
steve817
3:19 AM
Casper Wyoming
Contact Devinism here on FBBO and he will restore your dash dimmer switch.
Russ Hood
4:19 AM
TN
Dome light working now. Thanks for the advice.
