I am getting some knock/detonation at WOT. Went one colder plug down didn't help. I am trying various timing and plug combinations to see if I can get it to run well without detonating.
Set up:
Car: 1970 Sat with a A904 and 271 rear
Engine: 1973 340 with an unknown aggressive cam and unknown compression with stock steel heads.
Set up: Have it a running a little rich right now and will get an actual A/F reading later in the week.
Variables and Combinations:
Fresh clean gas
Current set up is base timing 19 with a mechanical advance of limit of 14 via a new bushing. Total timing 33. All in at 2500 or so.
Went from 66 to 65 Autolite's. Still detonates.
In the next day or so when I get time to play with the car again I will try lowering the timing to 17/31 to see if it goes away. Not sure I want to retard it much more than that.
Looking for some reasonable suggestions. Slapping on the new Trickflow's is not reasonable unless you want to purchase them for me Lowering compression via thicker gaskets etc is what I am looking for input wise.
Set up:
Fresh clean gas
