Disc brake conversion
Hyper Henry
1:28 AM
Ontario,Canada
Wanting to replace the factory front manual drum brakes on my 67 Coronet with a quality disc brake setup. Who sells the best bang for the buck out there?? And will I have to replace my master cylinder??
Derrick
Have you tried searching the site, there have been several Disc brake conversion threads that can probably answer your questions. Actually scroll down and see the both of Similar threads.
Ebay....can get factory set up complete (based on the 73-76 A body) for 300-600 depending on power or not.
I see a set on ebay for 73-76 Plymouth duster,, wildwood disc set up kit. $ 639.00? This will fit 67 Coronet?
I used a Scarebird (I know, I know, for some reason he named his brake business that). Works great: uses brackets and bushings that he makes and allows your drum spindles to use off the shelf parts to convert your car to discs.
