1. old guys rule
    old guys rule Well-Known Member
    637
    210
    Sep 14, 2016
    Jacksonville, FL
    Local Time:
    1:36 PM
    What's everybody using what is Lube on door hinges?
  2. Billccm
    Billccm FBBO Gold Member FBBO Gold Member
    2,655
    2267
    Aug 3, 2016
    Tucson
    Local Time:
    10:36 AM
    Tri flow. Soak them at every oil change including lock cylinders and latch.
  3. MoparLeo
    MoparLeo NRA BENEFACTOR LEVEL LIFE MEMBER FBBO Gold Member
    1,463
    1296
    Nov 24, 2015
    Moreno Valley, So California
    Local Time:
    10:36 AM
    Use a dry type lube. Lubes with oily/tacky residue will attract dirt, debris etc... which will cause the door check rollers to freeze up, eventually causing the main pivot springs to fail.
    Have questions about Mopar door hinges ?
    Ask me before you do anything permanent to your hinges.
    Member discounts.
    Leo
  4. old guys rule
    637
    210
    Sep 14, 2016
    Jacksonville, FL
    Local Time:
    1:36 PM
  5. old guys rule
    637
    210
    Sep 14, 2016
    Jacksonville, FL
    Local Time:
    1:36 PM
    Yes, I have Lube them with White lithium in the past but it doesn't seem to stay even indoors for some reason. I have already broken 2
  6. 66383
    66383 FBBO Gold Member FBBO Gold Member
    2,683
    1946
    Jan 19, 2018
    calvert city, ky
    Local Time:
    12:36 PM
    Graphite.
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    By continuing to use this site, you are consenting to our use of cookies.
