Dreamed of owning a Hemi???
mark42202
6:26 AM
Sparta, TN
I'm selling a completely finished Mopar Performance non-siamese standard water iron hemi block (casting number P5007669AB, with ears drilled for wedge motor mounts!!) , JE pistons with JE rings, .990 pins with double spiro locks, Manley H beam rods with bearings, and a complete Dvorak rocker system, all NEW NEVER RUN, for $7000 + freight!!!! The block has a 4.25 finished bore and was built to be a 472" pump gas motor. The pistons are designed for 10.5:1 compression ratio. This engine was completely assembled but never wired, plumbed, or turned over before we decided to go in a different direction with the car. This is an absolutely AWESOME opportunity to finally own that Hemi you've always wanted! All you would need is a set of heads, crank, lifters and cam to have a 472" pump gas monster for under $10,000!!!! Again, EVERYTHING IS NEW!!! Block and components are located in Sparta, TN.
the block alone is worth over $3k....i know, i work at a dodge dealership, lol. GLWS!!!
Yep, exactly! Add in the machine work, $2600.00 rocker assembly, rods, pistons, etc. and someone is going to get one Helluva deal! Priced it to get it rid of it quickly. Thanks for the bump!
Damnit, why did I have to buy that engagement ring NOW of all times!?!
Someone is going to get a great deal and good start on their hemi project.
Great! See you are from Sparta, thats not so far from where I bought my white 68 Plymouth Sport Satellite, bought it in Wartburg maybe you have seen it before?
I don't believe I've seen the car before, but Wartburg isn't too far from me. There aren't too many of us Mopar guys around here, so I would remember it if I saw it!
Awesome!! I threw in a few freebees that I think he'll be pleasantly surprised with
Thanks Mark!! That is awesome! Will post some pictures of my Cuda when I have the time to make a project thread somewhere.
Per
mark if u ever make it to soddy-daisy look me up. aint many mopar people here either.
