So driving along enjoying the sound of the 426 purring in the breeze and then hesitation....and cut off! Swing car into left turn lane and coast to a stop on a neighborhood street all the while fighting the power steering which now has no power. Turn the key and the engine starts back up, pump the pedal and she sounds fine. I had just left a gas station having filled up from 1/4 tank so I'm thinking either bad gas, trash in the fuel filter? I need to get home, only a half mile away, turn back onto the highway, get about a hundred feet and she stalls again, this time only a church parking lot available to get her off the street. I turn the key and she wants to fire up but as soon as I release the key she dies. Tried this several times before realizing I'm not driving home from this one. I take off the air cleaner, gas squirting in carbs, no obvious reasons she won't start. Call a tow truck. An hour later and $150 lighter (only .5 mile from home) I get her in the driveway. Can't get her in the garage, uphill and the tow truck only got me in the driveway. Check the fuel pump, fine. Fuel filter, fine. Will check again tomorrow (92 degrees and frustrated). Today, start checking the engine wiring harness and notice a burnt connection at the 4 prong plug on the passenger side valve cover where the alternator/coil connect to the engine harness. The black wire and housing around it are burnt, plastic melted. Checked the fire wall connections no signs of damage. Of the four wires in the plug, only the 12BK is damaged. I cut the wire from the harness and splice it together and still the engine will not remain running. Only runs with key in the crank position! Release key, engine dies. No current at the ballast with the key in the on position. Ignition? Harness? Ammeter? No blown fuses. Original ignition system, harness and dash components.
, good luck with the fix
