Dibbons
- 11:19 PM
- Nov 29, 2014
- La Paz, B.C.S., Mexico
Everyone has their own opinion (may be talking about plastic fan flex, not the same with a fixed metal fan). Two from internet search:
Shoot for about 1/2"-3/4" clearance from fan to radiator. The very important shroud should have 2/3 of the fan inside the shroud and 1/3 of the fan outside the shroud.
The last measurement you should check is the distance from the face of the fan to the radiator. There should be at least 1 inch of clearance between the two. This is to accommodate normal engine and radiator movement, and also the flex that occurs in the fan blades at higher engine rpm.
