FOR SALE Fitech 600hp System
Mopar Performance Parts For Sale
Thread Status:
  1. magvan
    magvan Well-Known Member
    175
    60
    Aug 3, 2012
    near disneyland
    Local Time:
    7:43 AM
    Contact Seller
    selling my fitech efi. it is the 600hp system,
    i have ran it for 7500 miles and it has proven itself. runs great no issues. i ran it on a big block mopar 440
    comes with upgraded temp sensor (stock ones often fail right out of the box)
    has the newest software installed
    has the large gage wire harness (the old harness are like 20 ga wires)
    extra ground wire
    air cleaner stud & wing nut included (doesnt come with it from fitech)
    fits any 4 barrel intake manifold. square bore or spread bore
    you can have the efi control the ignition timing if you want to but not necessary
    the only reason i am selling it, is because i installed an Edelbrock Pro Flo 3, 8 injector sequential injection system and dont need this one now.
    $750
    • Like Like x 3
    • dart6
      dart6 FBBO Gold Member FBBO Gold Member
      225
      5
      Sep 11, 2009
      Auckland
      Local Time:
      10:43 PM
      I’m interested your inbox is full
    • magvan
      175
      60
      Aug 3, 2012
      near disneyland
      Local Time:
      7:43 AM
      i just deleted a bunch of stuff (i think)
    • Cojohnso1
      Cojohnso1 Well-Known Member
      385
      305
      Feb 25, 2019
      Minnesota
      Local Time:
      7:43 AM
      Can you elaborate more on fuel pump requirements? And if possible fuel metering range? Can it be configured to push more fuel for alcohol blends like E-85?
    • magvan
      175
      60
      Aug 3, 2012
      near disneyland
      Local Time:
      7:43 AM
      i ran an inline walbro 255 pump and am still running it with the edelbrock pro flo 3.
      sorry i know nothing about e85, but they do talk about it on the facebook pages. i know alot of people on there run it.
    • dart6
      225
      5
      Sep 11, 2009
      Auckland
      Local Time:
      10:43 PM
      so it doesn't need an in tank pump, is that right
    • magvan
      175
      60
      Aug 3, 2012
      near disneyland
      Local Time:
      7:43 AM
      no inline works fine, but you can do a in tank if you wanted
    • dart6
      225
      5
      Sep 11, 2009
      Auckland
      Local Time:
      10:43 PM
      ok thanks, what disi did you run and did you run a return line to your stock tank
    • magvan
      175
      60
      Aug 3, 2012
      near disneyland
      Local Time:
      7:43 AM
      yes return line to the tank. the best way to do it
      i ran a stock 440 distributor. i didnt have timing control hooked up. i was always going to but never did
    • Cojohnso1
      385
      305
      Feb 25, 2019
      Minnesota
      Local Time:
      7:43 AM
      How much fuel pressure? I'm also assuming you are using stock fuel lines? 600+ horse builds is about when one thinks of running 1/2" line. I ask because I have both. A 450 horse 440 with stock lines to carb. And 700 horse 451 that runs 1/2" lines from fuel cell. Just feeling out how adaptive of this option?
      Thank you for your input.
    • magvan
      175
      60
      Aug 3, 2012
      near disneyland
      Local Time:
      7:43 AM
      fitech uses 58 psi so you need a pump capable of more than that. walbro 255 is over 100 psi free flowing and they make bigger more liters per hour pumps too.
      i ran 3/8 feed and 5/16 return lines but you can run anything bigger than that, it wont hurt going bigger.
      i only have about 400hp so i didnt need anything huge. plus remember with efi there is constant high pressure fuel flow all the time, its different than a carburetor fuel system
    • dart6
      225
      5
      Sep 11, 2009
      Auckland
      Local Time:
      10:43 PM
      pm sent
    • luvthyapril
      luvthyapril FBBO Gold Member FBBO Gold Member
      166
      77
      Jan 13, 2013
      Baldwin Park So. Cal.
      Local Time:
      5:43 AM
      Just curious you mentioned the updated temperature sensor did you get that from f i Tech. Thanks
    • magvan
      175
      60
      Aug 3, 2012
      near disneyland
      Local Time:
      7:43 AM
      Delphi from napa. its just a stock sensor for a gm truck
    Thread Status:
    1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
      By continuing to use this site, you are consenting to our use of cookies.
