manes
!971 340 mag
block has been bored 30 over, all needed machine work to block is done, SCAT 4.00 inch crank installed, freese plugs installed, cam bearings installed, motor is internally balanced, come with KB pistons,SCAT I beam rods with rod bearings installed, piston ring set, rebuild gasket set, hp oil p/u, the original heads from the motor comes with this lot("J" heads)as well as the cast iron 4 bbl intake, the HD torque flight trans that was coupled to the motor from the factory goes with it. motor and trans ran awesome before i started the rebuild, the mechanic ripped me off for the money to buy the heads which halted the build
the build that i was following calls for open chamber aluminum heads. the final displacement will be 416 c.i.
would consider trade for a rust free 1971 charger rolling shell, when i say rust free i mean no fame or floor /trunk rust, quarters can have a little, minimal
