JAS14
New Member
I recently installed the Edelbrock EFI system on my 71 Charger 440. The car will start right up and run for 5-10 seconds before it sputters and dies ( It dies quicker when I press the gas to try and prevent it from dying). I have constant 50lbs of pressure on the fuel rails. All the parts on the car are new, fuel pump, fuel lines, wiring ect. SOMETIMES the car will run fine for 2-3 days like nothing was ever wrong. But then The constant fire up and die problems come back a few days later.
At first I thought the gas may be the issue, so I bought a new gas tank, and put fresh gas in it, however the problem has persisted.
Items I have replaced: Ignition switch, blinker circuit, gas tank, gas, fuel pump, distributor, Valley pan, Coil, spark plugs, spark plug wires, All gauges, the motor is completely rebuilt with new edelbrock EFI system installed and timed the motor.
I've contacted the guys at Edelbrock and they were less than helpful. They suggested adding fuel to the computer, which I did, However the problem wasn't fixed. All that did was burn out the plugs. The car ran better with the fuel addition set to 0% than it did when they had me bump it all the way to 50%.
So, I reset the fuel settings to 0% across the board and it actually fires up and runs for 10 seconds before dying. I've played with the fuel and spark settings but there isn't any change. I can drive the car around town one day,with fuel settings at 0%, then come out into the garage the next day, and it fires up, runs for 10 seconds, and dies.
I'm open to Any ideas or suggestions. They would be greatly appreciated. Thanks in advance.
