mala
My current set up is:
Tank sending unit is a stock 3/8" ( New is 1/2" )
Fuel line is stock 3/8" ( New is 1/2" )
Mechanical fuelpump
From pump to carb is an-8
And I have a little return line 3/16 with a jet back to tank, return is located between pump and carb.
This has work ok so far, but I was little concern that this not fed motor on a 1/4 track.
So I bought a new tank sending unit that is a 1/2" ...... Or should have been a 1/2" but the tube is flattened in the bends. My thought was to use the tank sender anyway and a 1/2" fuel line to the fuelpump.
Now the Q: When I stage on track and the pump "filling" the whole system.... Can I use my bigger fuel line as a "reservoir" and have it to fed my pump for a couple of seconds longer here?
Thanks!
Mechanical fuelpump
Thanks!
