Runner12
Hey Guys,
this is my first post so bare with me
I have done some research on other threads but I can’t find exactly what I’m looking for I don’t think….
picked up my 69 Road runner with a 75 block 440. Ran fine, did some timing adjustments, high octane fuel and the basics. (Oil change etc)
Pumped I have this running car not needing much….
Next thing I know the car dies while driving. Will crank but not start. Wait 10 minutes it will fire back up. No other issues for about a week or so of driving. Now I can’t drive 3 blocks without the car dying. I can idle in park or neutral and rev to the moon for 5-10 minutes and the issue will not occur. Only under load.
New dist cap, rotor, and ignition coil doesn’t fix it. I eliminated the old fuel filter and it added flow and power but still died. As I sit there, I hear this bubbling noise from the fuel tank and I open the cap and sounds like pressure released. (Boiling?)
Sometimes it will limp home but most of the time it will die out.
I just switched to a better 91 low or no ethanol fuel (i was told) before this all started. I bought a new vapor separator/fuel filter but I’m not sure where it goes at the tank? I don’t have a 3rd nipple on the sending unit to hook into… could I replace the factory vent line with this return line and install a vented gas cap?
Am I on the right track to eliminate this issue?
Everything is appreciated
